Flexible thin smoke license plate protector
Lookin to find a flexible thin smoke license plate protector. I have the Kuryakan curved license plate holder & frame on my Street Glide and want a smoked "cover" over the plate..all the ones I find are fairly thicker plastic that wont bend, and if it does bend, it will be too thick, I guess sort of like a binder sheet only smoked..any of this rambling making sense ?
Oh, I dont care if its legal or not..I will deal with that if I have too.
Thanks
Thanks
I tried a piece of clear that is similiar in thickness as a "sample" - I can get it to bend, etc, it is just too thick for the Kuryakan curved plate setup, those screws dont have much thread on them and the raised numbers/letters add to the thickness..I may have found a solution, not sure of the actual thickness however, Lighting gel sheets for theatre lighting (a friend at work just suggested it) they have all kinds of colors..I may just try out a grey one for Shyts & giggles.
http://www.rosco.com/us/filters/ecol...r=co&display=0
Let us know how it works..I have the same frame..
WEll. I ordered a " light Gel" from a local theatre lighting supply .. Rosco pale grey # 397 - It is a bit thin, but it is the perfect amount of "smoke" I had a clear cover anyways, so basically I put the grey piece behind the clear one , sliced the holes for the screws and mounted it, it looks awesome. I will post a pic soon. the sheet is 24" x 20" for around 7 bucks. If you have a nearby theatre lighting place, I recommend that, cuz shipping on this is more than the roll.
