Why do we need an oil temperature indicator in our bikes?
Old 03-08-2010 | 07:18 PM
Toocold's Avatar
Toocold
All I know is that the people who make engines (cage and bike), to get better mileage, are putting thinner and thinner oil and more of it in the cars, trucks and bikes. I live in Alaska and don't really have heat problems but I like knowing that everything is "normal". Makes me feel like I'm in control of something.
I look at the air temp to be on the lookout for icing conditions. Not unusual to get snowed on in July in a few places. In March April and toward September and October the temps get down in the 30's.
I do wonder if the guys with CVO's noticed anything in the oil temp area before they had problems.
Old 03-08-2010 | 07:49 PM
Gliden's Avatar
Gliden
OK THEN.....
Anyone know of an oil temp gauge that matches the white faced gauges of an 09 Glide?
Old 03-08-2010 | 07:57 PM
themensh's Avatar
themensh
Originally Posted by Heatwave
It's pretty simple. It's an aircooled engine. The only coolant to the engine is the air over the fins and the oil circulating around the engine (and to a lesser extent the fuel being sprayed in the cylinder).
I can't think of a single watercooled auto engine that doesn't provide an engine temp gauge or at least an engine temp idiot light.
Think of an oil temp gauge on an air-cooled HD engine as serving the same purpose as a coolant temp gauge in a water cooled auto engine. Both can give you a heads-up to the need to shut down the engine before real harm is caused by overheating. All the more important in an air-cooled engine that can easily overheat on a hot summer day while caught in traffic.
The really sad part is that HD should be providing this type of temperature monitoring as standard on all their bikes instead of making it a profit generating accessory.
My lawn mower is aircooled also..as is my weed eater. I owned a 1970 VW dune buggy....yep, aircooled. Never worry about any of them (my dune buggy had the fan ducts capped off...)
You can't think of a car without a oil temp gage? You drive much?
Most cars that I have owned only had an idiot light that displayed when OIL PRESSURE was low....not temperature.
As I have mentioned before....next time you see a group of Harleys parked...just
walk up and see how many have oil coolers. I don't think they are needed, but what
ever floats your boat.
chuck the mensh (going to try and over heat my lawn mower)
Old 03-08-2010 | 08:03 PM
Streetrunner's Avatar
Streetrunner
Originally Posted by Gliden
OK THEN.....
they are in the HD catalog. Just installed one in my SG. Check my thread on oil gauge test results.
Old 03-08-2010 | 08:26 PM
emwolb's Avatar
emwolb
there seems to be some controversy with the use of an oil temp gauge or the oil temp dipstick. i don't feel the need to be that paranoid. the engines are designed to be run at all the temperatures and conditions that we'll encounter on this planet. if i had one on my bike, it'd be very annoying to see the numbers, as i'd think it's running too hot. the air temp gauge in the glide fairing is useless, but that does not obligate me to install something else that would be annoying. if i wanted something that was truly annoying on my bike, i'd be shopping for a wife who is also a sumo wrestler who has a tendency to whine constantly.
Old 03-08-2010 | 08:57 PM
1plumr1's Avatar
1plumr1
I have the digital temp/oil level dipstick one. Mostly to check the oil level, but it is interesting to see where the oil temps are. Temps run spring and fall@180, summer @210. Being lazy, it's easier to push a button than to pull the dipstick.
Old 03-08-2010 | 09:11 PM
Punjabi Rider's Avatar
Punjabi Rider
I was going to put one on mine but a friend of mine been riding for 50 some years told me save your money fool if you think bike is hot just find a convenience store buy yourself a 6 pack that will cool you off and by then bike will be also cooled off too and it's lot cheaper and requires no modification.
Old 03-08-2010 | 09:17 PM
Quadancer's Avatar
Quadancer
First off, Harley would love to sell you more bikes. They have no vested interest in making them last forever, so why put devices on there that could cost them even more?
Second, wrong about the oil breaking down. Oil doesn't wear out; it gets diluted or polluted, and otherwise remains oil unless it gets burned.
What breaks down is the additives that are designed to make your engine last longer. Ships and the like that have thousands of gallons do not ever change the oil; they purify it with centrifugal purifiers. Unless it gets fuel oil (diesel) dilution, where they send it off to be re-refined.
So by doing whatever keeps your oil in normal operating parameters, you keep it functioning as designed, and the engine benefits by lasting longer. At least that was the official position of the US military (I was a USCG engineman), and they tend to depend on their equipment a lot.
From what I read, syn oil is no different as far as additives go.
Old 03-08-2010 | 09:27 PM
PistonPuller's Avatar
PistonPuller
Good point. I am a Marine Engineer. and we do in fact run lube oil through purifiers 24 7. We don't completely change oil in the main engines or auxiliaries. If an analysis indicated high level of contaminants, then we would off load it and bunker more. You will always loose a little at a time and end up adding 1/2 cubes to the sump every few weeks. But yeah I have seen ships use the same oil for years. The last ship I was on was still on original oil for 3 years and the ship run 24-7-365
Old 03-08-2010 | 09:31 PM
davessworks's Avatar
davessworks
I haven't run a temp gauge since my 1992 Fatboy. I'm considering getting one for my Ultra. There's something to be said for knowing what the oil temperature is as specific riding styles can effect oil temperature (speed, standing idling, hard acceleration etc.) Running through the desert with road temperatures in excess of 110f is very different from riding in Washington State at 75f.
