Transmission Exhaust Bracket ?????
I'm looking a buying Hookers true duals exhaust system. I have an 03' RKC and I can get a smoking deal on the system that is made for 07-08 models. The offer specifies I would have to modify my current transmission exhast bracket for it to fit. My question is if this would be a tough thing to do and not be worth it, or is it an easy modification. Does anyone have any experience with this? I'd appreciate any help I could get. Thanks
The bracket on my 08 is a simple flat tab with a hole in it. The exhaust has a mating tab that rests on top of the tab and a bolt slides through. The one on your bike is a U shape bracket in which a clamp goes around the exhaust and through it. Best to check and see if the 08 bracket would mount to the same holes in the tranny. If so, simply swap them out. If not, modify one or make your own.
crusader1xxx
05-25-2018 01:52 PM
