PCV Autotune Problems??? Please HELP!!!
Fuelmoto is SPONOR OF THE YEAR!!!!
Jamie,
Thanks so very much for chiming in. You and your company are awesome. I can't get to checking out the modules for the rest of today. My four month old has got a very bad cold and his Mom is working. So, me, Dad... am watching my "little harley buddy". I will check things out tomorrow and get back in touch with you....
THANKS VERY MUCH FOR YOUR HELP!!!!!
Scott
Scott
I think it might be the front O2 sensor
Jamie,
I swapped the modules and the sensors. Now, cylinder 2 is now not showing anything. When I plug the laptop into the bike and fire her up, I am showing AFR readings for cylinder 1 and 9.99 for cylinder 2. It's either the O2 sensor or the long cable between the O2 sensor and the module. I am betting on the O2 sensor. I'll give you a call in the morning to discuss.
In addition, the map switch I installed seems not to be working. Either way I put the switch (open or closed) my dynojet software shows AFR readings (for the cylinder that is working). Is that correct?
Thanks,
Scott
Thanks,
Scott
The AFR for the working cylinder will also show the change, but again if it it isn't great you may not see it. The O2 sensor is polled 50x/sec. and is constantly changing, making it hard or impossible to see these differences if they are small.
As for the question about the check-engine light, it is normal for it to stay on for ~4 sec. after starting with or without a PCV, at least on the '07.
