Batwing Fairing Air Deflectors
Old 03-07-2010, 06:15 AM
emwolb's Avatar
emwolb
emwolb is offline
that's one of the first things i added to my streetglide. i remember having to tap the holes in the brass inserts for the screws though. i used the harley ones, dark smoke on my black bike look just fine, and they do give you the option of controlling the air flow to or away from you. for me, they're great for cold weather and for hot, as you have the choice of airstream control.
Old 03-07-2010, 07:33 AM
buckwheat's Avatar
buckwheat
buckwheat is offline
Being 6'4, I could care less about how these things "looked" (by the way, they look just fine). They made a huge difference (arguably the most noticeable difference compared to lowers, and the air baffle at reducing wind buffeting). Basically, it pushes the oncoming air further down (more toward your legs) so that it won't hammer you further up your torso and eventually, up to your glasses and helmet (if you wear one). I have a black bike, and went with the black deflectors which give the batwing an even more formidable look when its coming at you head-on. For $99, its a great investment toward a more comfortable ride. Very easy to install.
Assuming you're buying these for a more comfortable ride, I'd say go for it.
If you're buying these for "looks", then let your own tastes decide.
Old 03-07-2010, 07:46 AM
santajim's Avatar
santajim
santajim is offline
Mine came on my bike and I use them year round, closed in the winter open in the summer. They do help with the air flow, and I don't think they look bad at all. JMO
Old 03-07-2010, 08:10 AM
Vatorman's Avatar
Vatorman
Vatorman is offline
+1 Glad you wrote all that so I didn't have to. Anyone that sacrifices function over fashion probably watches Opra as well.
Old 03-07-2010, 08:26 AM
frozensoul's Avatar
frozensoul
frozensoul is offline
between a 7 inch windshield and the freedom wings i have just about whipped the wind problem on my street glide. i still get wind but it dont feel like im getting hit by a air compressor now. the two have made a huge difference for me personaly.
Old 03-07-2010, 08:41 AM
mphamrick's Avatar
mphamrick
mphamrick is offline
Like binkman78 said they really work well in the winter time keeping the cold air off of you.
Old 03-07-2010, 11:29 AM
BeeRAD56's Avatar
BeeRAD56
BeeRAD56 is offline
Thanks for your input. That's the feedback I was looking for. I'm adding the deflectors to reduce the buffeting. I'm 5'-10" & 32" inseam so the stock 4" shield actually worked for me. I put on a 6" LRS with recurve (nice shield by the way) to see if that would help and the problem actually got worse. All the turbulence is coming from underneath. I wear perscription goggles and a half helmet and the buffeting above 60 can get to the point where it shakes my googles and badly distorts my vison, not to mention trying to rip my helmet off my head.
My question is more of which ones to go with. If the freedom wings are as effective as the HD version, I'll go that route and save $40 bones. I like the outside shape of the Kuryakan version and wonder if they are more effective than both the HD and FW?
Thanks again to all for the input.
Old 03-07-2010, 12:03 PM
imskier2's Avatar
imskier2
imskier2 is offline
I had kury wings on my 06 and didn't like them, But the new Harley wings are great, infinite adjustment, the kury ones you had to lift up to adjust and had, I think 4 adjustments, very hard to adjust while riding, HD is very to adjust while riding Summer or Winter. Love Mine
Old 03-07-2010, 01:14 PM
bmaier's Avatar
bmaier
bmaier is offline
Don't have experience with the other deflectors but the dark smoke factory HD wings work excellent and for you Oprah watchers, they look badass, ha!
Old 03-07-2010, 06:42 PM
Jerm21's Avatar
Jerm21
Jerm21 is offline
I took my first ride with the HD wings (same as the Kuryakyn Dragon Wings) and overall am very happy with the amount of wind they block coming under the fairing. They have 5 positions and are pretty easy to open/close when riding. I found that they reduce the amount of wind on my legs as well as my midsection. Overall, worth it, especially for the cold.
The only negative that I found is that the vibrations at certain RPMs are making them rattle a little when in the closed position. This is making me think I may have to check my fairing brackets… .
Quick Reply: Batwing Fairing Air Deflectors
