Where to get paint?
I pulled this out from my Bookmarks. It was posted a while back and folks seemed pretty happy. I have no personal experience from them though.
http://www.colorrite.com/
Have you tried the dealer? Check at the parts department, you could by quarts not to long ago. Also goto an pure automotive paint store, one that sells body shop supplies. Ask em to look up your scoot, PPG brand of paint most likely will show right up. Maybe things have changed but most paint is there unless you have a CVO bike.
Just phone or stop by your local PPG automotive paint distributor or an auto paint shop that has a PPG mixing facility. They have computer software with thousands of OEM paint codes and forumulas to repair autos and also have the information for HD paints. They can mix any quantity you want; HD sells your paint, but only in quart quantities which is way more than you'd need to do an inner fairing.
You should be able to visit any PPG dealer. There they will have color codes, as well as color samples. However, just because you have the 'proper paint' doesnt mean it will match, especially with a three stage paint such as pearl. I just went thru this painting a TP in mirage orange. The best advice I can give, is to take to an experienced painter, that way should it not match you dont have to be the one to try to fix it.
But I would like to try and do this myself and if I screw it up....I screw it up.
I can always try to fix it myself, take it to an experienced painter to fix it, or even replace it if it is THAT BAD.
I've always been the type of person to try and accomplish something myself. It gives me a great sense of pride. I knew almost nothing about automotive engines when I started rebuilding a 351 to put in my '68 Mustang, now that thing runs like a champ.
But I DO appreciate the advice. Keep it coming.
Hey, Im all for doing it yourself, saving some money, and wearing the pride. I had that same approach tackling my project, but after spraying twice, Im ready to turn it over to someone else. I spent around $150 in paint for a pint of orange, pearl, and clear. Im just saying its costly to redo, not to mention the time involved. The supplier of my paint proclaimed that learning to paint with a three stage, is like starting to play football in the NFL, but if your motivated then Im pullin for ya.
First if the Pacific Blue Pearl a stock color you will have no problem finding the paint code by going to a PPG dealer. I on the other hand have the light and dark candy root beer which was a custom color in 2009. I spent half a day between the stealer and HD headquarters to find out that I cant by the paint in any quantity or get the code so I could have it made. But I took a part of the bike and took it to the PPG shop and they matched the paint by using a machine to read the colors then they mixed them.
