Noisy Clutch chirp 01 Roadking
2001 Roadking. Changed the fluids replaced them with Syn3. New To me bike and not sure what was in it before.
Clutch was very close to the bar with a lot of slop so performed the clutch pack adjustment. Turned the adjuster screw in until I felt it touch the pushrod. turned back half a turn and locked the jamnut. Adjusted the clutch cable so I have 1/16" at the cable.
Now when I run the bike I get a chirping noise when I pull the clutch in. Pulled the pushrod and adjuster out and the ends look blue'ed from heat. Don't think the heat is from right now because once I heard the noise I shut it down and did not ride it. The ball ends of the pushrod are not galled and still very smooth.
Any idea's what could cause the noise?
I have had a poor adjusted drive belt that chirped!
Doesn't sound like the OP's problem since it didn't start until after the clutch adjustment.
But might be cuda67's issue.
