Brembo conversion finished--at last
Finally “finished” the Brembo conversion on my ’04 EG. More than a year ago I installed the Brembo calipers (silver from an ’07 V-rod) and ’08 rotors. For budgetary reasons, I retained the pre-’08 chrome controls I had on the bike and the Brembo calipers worked at least as well as what I had previously; probably better, in fact, but I never conducted any tests to prove it one way or the other. Here's a pic of the installed calipers and HD stainless brake line:
http://
Picked up ’09 OEM take-off clutch perch, master cylinder and brackets; sent them to Atlas Plating in Houston for chrome plating; and, purchased a set of chrome aftermarket ’08 and newer Touring levers. Installed everything last week and have ridden the bike 200+ miles.
Still no empirical data, but the completed Brembo conversion makes a startling difference in braking compared to the pre-’08 system. Frankly, I’m concerned that I will need to pay attention to lever pressure in an emergency stop to avoid locking up the front wheel. So, I’ll practice to get used to the increased braking available.
WVULTRA has done an exhaustive treatment of the conversion complete with part numbers, pictures, etc.:
http://www.box.net/shared/nhergtkq5r
For my meager contribution on the topic, just a few footnotes to his write-up. As mentioned, you can use ’06 and newer V-rod calipers (and I was pleased to use silver calipers). Also, you can retain the stainless brake lines if you have them on your bike (which I did; they’re HD’s that were used on the ’04 and ’05 CVO EG’s). The OEM rubber brake lines won’t cause a fitment issue, but the Brembo system is a higher hydraulic pressure system which the OEM rubber lines probably weren’t designed to handle; just check the lines on an ’08 or newer Touring model and compare them to the ’07 and older rubber brake lines.)
Also, due to the chrome controls, I used a “bright” finish banjo bolt at the master cylinder, HD p/n 42010-06. I’ve ordered a chrome brake lever pin, HD p/n 42105-06A (since the aftermarket levers came with a black brake lever pin, and the pre-’08 chrome pin I had was too large a dia. to use). I reused the chrome clutch lever pin.
I did the R&R myself (it’s a very straight forward swap as explained by WVULTRA), but was stumped when it came to bleeding the new master cylinder. I’d had no trouble bleeding the brakes when I installed the calipers; but gave up after a couple of unsuccessful attempts to bleed the system with the new m/c with a Mighty Vac, and had the dealer do it for me. The tech who did the work took the bike for a test ride and was blown away by the difference in braking; he’ll be doing the swap on is personal bike after test riding mine.
As for the all important question of cost:
Calipers: $100 (sold my take-offs for $60);
Rotors: $60 (sold my take-offs for the same price);
Stainless brake lines: $100 or so—reused mine and it’s been a few years since the purchase;
Clutch perch, m/c, and brackets: $20 at dealer’s swap meet;
Atlas Plating (Houston): $125 plus $12 shipping (clutch perch, m/c, m/c cover, and brackets)
Chrome levers: $50.
If you want an easy project that you can justify as a real enhancement to your ’07 or older Touring model, this is a great one.
PS: I did only the front calipers. The rear will remain the OEM system.
http://
Chrome levers: $50.
Great looking job. The silver work well for your front end. These front brakes are so much better than the old ones!
FYI on the rear Brembo conversion. I did the rear conversion only because I went to a wider 16" rim and the Brembo caliper fits without modifying. I did not replace the reservoir and I did not feel any improvement in performance from the change.
i am in the process of collecting all the parts for the conversion, looks like you di some good shopping considering the prices i have found, i only have rotors so far and the current work situation (or lack of) has stalled the project temporarily. looks like a great bang for the buck improvement although i will be skipping the chrome. thanks for the info and link.
I had the same results as Harleypingman, I pretty much broke even buying and selling on Ebay, just take your time and only buy when the price is right.
I didn't realize what a "bang for the buck" mod it is until I installed the m/c.
Ebay is your friend coupled with patience. Also, try the service departments at dealerships for take-offs.
If you want black, like new, calipers for $100, shoot me a PM with your contact info and I think I can hook you up with a tech at my local HD store.
Carl
Carl
