Check this half size trailer.Would you use it?
Old 03-04-2010, 11:32 AM
powaypete's Avatar
powaypete
powaypete is offline
Many years ago, moving from Memphis to San Diego, I pulled my bike (72 Sporty) simular to that. The truck was full of my stuff, got a reciever hitch, welded a used front axle to it, removed the front tire, bolted the forks to the hitch, and pulled it all the way without straps. When you're poor, you can do anything.
As for emergency use, if that is all there is, ???
  #32
Old 03-04-2010, 02:08 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Had a very similar one in the 70's from JC Whitney. I used it a few times and had trouble when turning. The bike wanted to lean over. The straps then came from the center and you tied out to the handle bars.
This looks like a better design for the strap location and should control the bike better. Ratchet straps are better today than the slip type I used back in the day.
I would say that they would work but they should be checked often and used slow and as wide as possible in turns.
I have just under $500 in this:
You can have it for $400.
Towed and 840 lb Rune 1,500 miles. Tows like its on rails.
  #33
Old 03-04-2010, 02:17 PM
santajim's Avatar
santajim
santajim is offline
Not in this lifetime
  #34
Old 03-04-2010, 02:57 PM
rockhard69's Avatar
rockhard69
rockhard69 is offline
no way
  #35
Old 03-04-2010, 04:04 PM
kc347's Avatar
kc347
kc347 is offline
Looks like something Reid or Pelosi would design. The Mistress would never stop screamin' if I tried to strap her to that thing!!!!
  #36
Old 03-04-2010, 04:19 PM
Sancho's Avatar
Sancho
Sancho is offline
Originally Posted by c50plus
What do you guys think about this trailer. See link below
http://www.cycle-tow.com/
Not for me.
  #37
Old 03-04-2010, 04:41 PM
Fitter64's Avatar
Fitter64
Fitter64 is offline
Excellent REPO trailer.
  #38
Old 03-04-2010, 04:47 PM
Master Gunny's Avatar
Master Gunny
Master Gunny is offline
NO way!! Google "Stinger" if you're looking for a small, compact trailer...
  #39
Old 03-04-2010, 05:08 PM
hddan502's Avatar
hddan502
hddan502 is offline
NO I do not think I would.
  #40
Old 03-04-2010, 05:36 PM
brockstwrt's Avatar
brockstwrt
brockstwrt is offline
No way in hell
Quick Reply: Check this half size trailer.Would you use it?
