SG Fascia & Tail Light on my Roadie w Pics
Old 05-04-2010, 01:32 PM
adlerx's Avatar
adlerx
adlerx is offline
Originally Posted by domeix235b
First the rear fascia, then the streched bags, and now the SG wheels. I bolted the fascia since I didn’t trust two sided tape.
08 FLTR Vivid Black - Color matched inner faring
Screamin Eagle Stage II - 103 ci 255 cams
TTS MasterTune
HD Premium Oil Cooler
Vance & Hines Ovals
Hawg Wired CX504 speakers and 1502 amp
XM Radio
HD Conquest GPS
Kuryakyn Driving Lights
Road Glide Headlight Bezel
Bagger-Brace Stabilizer
Glide Pro Bushings
Harley Pillow Seat and Detachable Backrest (Cross country setup)
Linbar Highway Bar
Soos Floorboard Extensions
TopShop 3” extended bags (Paint by Spade Bros. HB CA)
Lighted Rear Fascia
Street Glide Wheels
Get yourself a decent windshield and you'll be about done. I reccomend a 12" Gunsmoke WindVest
  #52
Old 05-04-2010, 11:22 PM
heywood727's Avatar
heywood727
heywood727 is offline
Default Rear Facia and SERG Bag Extentions
Well I got the pieces back from the painter and installed.
These age just a few teaser pictures from my phone. Once the weather clears up and I have time , I'll get some better res pictures to show the color off in the sun.
  #53
Old 05-04-2010, 11:37 PM
adlerx's Avatar
adlerx
adlerx is offline
Looking good Heywood! send mine off to painter next week. Gonna have him fill the holes.
This is a great thread to learn all about the SG taillite setup. I have purchased the tribar lite but ordered the one with no brake. Not enough research, bad me Also bought a street glide complete tail light setup but think I'm gonna resell that. Bought a lens for my RG setup and ready to order plate mount.
Loving the look of all these red baggers with the fat arsses on em!
  #54
Old 05-05-2010, 12:09 AM
heywood727's Avatar
heywood727
Well since you did the same mistake as I did, you'll have to get the blank plug so you can use the plug in to the tail light like I did.
BTW, the foam piece that has double sided tape is to stick on to the rear fender bracket at the bottom. I didn't have any instructions, but found this out after I got into it.
As for the holes, I just bought the HD rubber plug and gromet for the attenna.
  #55
Old 05-05-2010, 12:40 AM
sifularson's Avatar
sifularson
sifularson is offline
Here's my Road Glide rear end. I like the stock plate location up under the tour pak.
Lit up with lighted rack.
  #56
Old 05-05-2010, 11:52 AM
Biggzed's Avatar
Biggzed
Biggzed is offline
Just a word of caution on the 3M tape. Mine finally came loose after 3 years. I am going to go in and install the brackets like HD does. After all those miles in sun, rain, cold, washes, etc. the tape finally let go.
Zach
  #57
Old 05-05-2010, 12:03 PM
sifularson's Avatar
sifularson
Zach
I'll keep an eye on mine too Zach. It's been a couple years.
  #58
Old 05-10-2010, 01:09 AM
barny43's Avatar
barny43
barny43 is offline
Stage I
Default Nice Job
You did a beautiful job on that fascia. I had just done mine also with a fascia that I bought on ebay. Went on easy and looks great.
  #59
Old 05-11-2010, 01:58 AM
99Roady's Avatar
99Roady
99Roady is offline
Originally Posted by Harleypingman
However, if you have the SG bullet turn signal/license plate kit on the bike, the socket in the circuit board you need for the fascia LED is already used for the license plate light LED's.
Carl
I have this SG bullet turn signal kit kit on my Road King and I am attempting to wire in the new style SG LED run/brake light and facia. As you stated the license plate light is already using the open spot behind the tail light. How would I go about wiring this in correctly?
Thanks for the help!
  #60
Old 05-11-2010, 07:32 AM
groupw's Avatar
groupw
groupw is offline
..... i bolted mine on & plugged the tri-bar into the tail light socket. Absolutely love that 'filled in & finished' look @ the tail end.
Quick Reply: SG Fascia & Tail Light on my Roadie w Pics
