Hd heated grips yes no maybe
#71
Just the one that came in the package. A Y split cable terminates between the battery posts and ran it up between the front of the seat and back of gas tank. Then a simple toggle switch plugs into the cable that connects to the gloves.
#72
#73
I got mine installed two days ago, not the easiest of things
to do with the wiring in the bars, but, I am very pleased
with the heating of them. I got out early this morning in 34*
and was turning them down as they were HOT coming
through my winter gloves, ended up running them on the
#3 setting out of #6 being the highest heat.
#75
#76
Heated Grips
Another vote for the Heat Demons here. I recently installed a set on my '09 Ultra. No problem with installing with the Throttle by Wire. You just have to unplug the connection under the fairing and slide the throttle assy. out of the bar enought to wrap the element around the assy. And because they actually install in the bar, you can use any grips. I have the Iso Grips. They are in the off mode during startup so no worries there either. They get so hot on the highest setting, you can't hold on to them without heavy gloves and this is without the bike running. I used them set on high to cure the epoxy for the left grip. Give Roland a call there, he seems like a very standup kinda guy to me.
Russ
Russ
#78
Just installed Paul Yaffe Monkey Bagger bars on my 08 SG and while yaffe was wiring them I had them put on the latest version (08a) of the hd aileron heated grips and love them. I have ridden only 100 miles with them but they are set on "1-2" WHICH IS GREAT WITH LIGHT GLOVES AT 55 DEGREES oops fricken caps lock.
Steve
Steve
#79
HD heated grips
I am on my third set of HD heated grips. When they work they are great. I had them on the bike new so the last two sets that kind of gave up the ghost were replaced at the dealer's expense. One set lasted almost two seasons and the other set lasted less than a month. The newest ones, put on in June of 09 are still working or were still working when the bike went into storage in November of 09. If (or should I say when) these go I am going for heated gloves. I have friends who have had similar experiences with the HD heated grips. Not one of your success stories from HD.
#80
