Hd heated grips yes no maybe
#91
#92
#94
#95
I have Hot Grips on my 95 RK and HD grips on my 09 RK. The Wife has HD grips on her 07 RK.
I like the heated grips very much. They are of most value to me when it is only slightly cold. That is, when it is not cold enough to make me stop and change gloves but cold enough to be uncomfortable. Just flipping (turning) that switch has often been a blessing. For real cold, heavy gloves/heated gloves have no equal.
The HD heated grips are very complicated. They have about 13 electronic components in the left grip. A simple high-low-off switch would have been better. I disassembled a heated grip last year. Do a search for my posts about that.
If I had to do it again, I think I would go with the Demons. Right now the grips on my Wife's have failed. I am seeking a work-around for that now. The grip itself can't be repaired.
I think we would be wise to bombard HD with complaints about the grips altho I can't imagine they do not know of the very high failure rate.
E
E
#96
#97
Lets see. $260.00 + labor unless you install yourself for the grips and life expectancy seems to be less than 2 years on average. I bought my Gerbings gloves on impulse from the dealer at $180.00 so know I could have paid much less and this with a satisfactory warranty. I didn't stay at a Holiday Inn Express last night but somehow I feel like I should have in order to do the math and figure out which is the better of the 2 options. Just sayin' is all.....
#98
i have them , installed them myself . they worked then didn't but with an electrical tester i found my problem ( a small connector socket pin had broke connecting the two grips ) but with some splicing and good rubber electrical tape on every connection they work great . wonderful . but i can see where the problem is with them and have read a lot about how they fail . but after struggling with them for a month i've learned quite a bit about them .
#99
#100
Big Kahuna HDF Member
i have used heated grips and heated gloves. the gloves were gerbing. the gloves are much better for warmth and were water resistant. they are not bulky. about $300 for gloves and thermostat. i didn't consider the battery operated gloves because of battery life was stated at five hours. one must have the thermostat to avoid baked hands.
