Loctite 271 versus 262?
LOCTITE® 262™ is designed for the permanent locking and
sealing of threaded fasteners. The product cures when
confined in the absence of air between close fitting metal
surfaces and prevents loosening and leakage from shock and
vibration. Typical applications include the locking and sealing
of large bolts and studs (up to M25 ). The thixotropic nature of
LOCTITE® 262™ reduces the migration of liquid product after
application to the substrate.
LOCTITE® 271™ is designed for the permanent locking and
of large bolts and studs (up to M25 ). For Disassembly Apply localized heat to nut or bolt to approximately 250 °C. Disassemble while hot.
