Shorty antenna, or antenna elminator?
On either of these, do you see reduced reception? If so which is better, and is the shorty close enough to the stock that it doesn't matter? I do listen to the radio often, probably will get a set of W/S bags and if I use an IPod put it in the bag,,, and I guess CD's are an option too, I forgot about that!
Just wanted to loose the tall antenna, I kick it sometimes, and it looks kinda out of place on that clean back end!
I just did XM and wanted to do an inside fairing antenna. Dealer recommended one that was supposed to be "really good"
I was about a half mile down the road and was just seeing how it was working. No AM reception at all and the FM wasn't too good either. The dealer called the manufacturer to see if there was something that could be done and was told "Well it's not an outside antenna"
Whatever. I ended up going with the HD shorty antenna. It seems to be just about as good as the longer stock antenna and doesn't look like a fishing pole.
BTW, the crappy antenna was made by JM.
That or the HD shorty will likely be what I do...
Here is a pic of the stock one relocated.
