2010 Ultra Rear Shock Air Pressure
I've always run 15 psi on my bike when solo and 25 psi when fully loaded including passenger.
I am just curious as to what other Ultra riders are running on the 2009 and 2010 versions.
I'm going to try a lower psi, just haven't got around to it yet to see if that would smooth out some of the frost heaves around here.....
SO, thanks, I'll go pump 'em up and give it a try. I appreciate other's findings on this.
09 and 10's with the new frame call for a different range for the pressure in the rear shocks. I run between 30 and 35 in mine. I ride solo about 2/3's of the time and double the rest. Mine had 0 in it when I picked up from dealer.
You need to play around with the pressure. I am 190 lbs. It seems most people run higher pressures but I found I made things worse. On a trip last May I was running about 18lbs and it was downright painful over certain types of bumps. I would brace myself in anticipation of the hit. I then lowered the pressure to 12 lbs and the ride was much better. I occasionaly bottom out but not very often.
FYI,your running well under HD's rec air pressure your your gen bike.
I have an 09 and it would be bottoming out often if i ran the low air pressure in stock shocks like you are.
Riding 1 up (170lbs) on my bike i run approx 25-30lbs & 2up (combined wt 310-315lbs) i run qpprox 35-40lbs with bags empty or lightly loaded & 50lbs with bags fully loaded.
Scott
