S&S Cams vs. Screamin eagle cams
My buddy is a mechanic at the HD dealership. I have a 05 RKC with a stock engine. He says I should get some cams to wake my engine up. For the price he's going to give me it sounds like a good idea. He is only familiar with S/E cams and suggested the 203's or 211's, but probably the 211's. Does this sound right? or should I go get some S&S 510's or other brand? I have gone to nightrider.com and printed out the comparison for him to review because I have no clue of what I'm looking at. I want useable power.
RE: S&S Cams vs. Screamin eagle cams
The SE cams were made by Andrews, this is a A class co. but as to cams, dont make the mistake many make, big is not better unless you want all your power around the redline point, useless on a touring bike , you want the power band to be low to mid range if you want more power while riding normal or with a passenger. Most cam info will tell you the range they come on at look for something in the power comes on in 2000-4500 range, this will give you great low end torque and cruisin roll on power.
Andrews TW26 (chain drive) or 26G (same thing w/gear drive) are AWESOME in baggers!
I am sure someone "manufactures" the S/E line of cams for HD, but simply based on the "look" of an Andrews vs. a S/E, I would be shocked if that were true. If you campare machining quality between the two... one looks like it was turned in a jr. high shop class and the other looks like high quality work... You can guess which one is which.
Hint1: In a recent thread, I referenced giving away a set of S/E203's for free....
Hint2: Andrews cams in my last 3 HD's
As always.... just another unsolicited OPINION!
[8D]
[8D]
I just put the S&S 510 in my 05 Ultra. Pulling 95 Torque and 90HP. Love the. Got the power where I need it!
Mid range, come on 2500 - 4500. Without question this is the right one for me and my Ultra!
SE Push Rods, Fueling Tappets, S&S Oil Breather, Jagg Thermostatically controlled Oil Cooler, Rinehart 2:1, SEAC, SERT and Mentor Fuel Processor (like Terminal Velocity).
I'm putting S&S 590's in my 06 SE Ultra as we speru along with Rinehart Ture Duals and much more
