Two map success
Two map success
After seeing the tread about using two maps with the PCV I emailed Jamie for a better MPG map. I installed a switch and the 2nd map and went for a 200 mi ride. I got 41 mpg. That’s by far the best I have got since installing my stage 1 system. The bike seems to run the same to me. See how the heat is once summer arrives.
On the Street Glide, you've got an accessory switch on the far right of your batwing that can be used to switch back and forth between maps. On my bike that switch is currently being used for my LED lights, so I'll buy another switch and install it on the left side (that's usually used on the Ultras), and use that to toggle back and forth between maps.
Be careful to ensure the voltage is disconnected when using that accessory switch.
You need a non-powered on-off switch.
I used a 1.50 metal on off switch from Advanced auto parts.. and bought a rubber cover for it to weather proof it. My switch is next to my top right gauge. Barely noticeable.
Not seeing much for better MPG though. Averaging 36 MPG on my MPG map and 36 MPG on my HP map.
Both from Fuelmoto. Need more time to be sure though.
