I've had the Arnott system for quite awhile now & really like it. It will only go down when you park it if you let the air out of the shocks. I mess w/ mine all the time (and I mean ALL THE TIME!) and have had no problem w/ the compressor (other than it's a little loud). You adjust the height so, you can put it where you like it. When you slam it all the way down it rides like a rigid with no fender rubbing and makes it much easier to back up the bike even for me at 6'2" & 280#. If you've changed your wheel/tire combo from stock, I'd call Arnott & tell them what W/T combo & bike you have and they'll set you up with what you need. Have never had a air leak problem even if the bike sits several days (rarely!). My wrench put the left hand switch housing off an Ultra & used the CB control switch for compressor control. VERY SLICK! Very happy Arnott customer here!
Hey, thanks for all the info. I got a RKC so I want the 13" because I'm tall like you. I got the 09 model so it has the fat tires, etc. I'll stay with stock because I like it pretty much as it is. Guess I'll add the Arnott system to my list.
did you install the 12" on your street glide.i have mine sitting in my dining room waiting for good weather so i can install them .
Yes. Arnott told me if I ever changed to larger wheels they would change them to 13s for free. Really nice system. Finding a good place for the manifold and the relays for a clean install was a challenge.
which arnott system are yall running the bilsteins or the more expensive aldans?
i got the alden 12" for 09 street glide same as stock when pumped up and can lower about 3".will report back when i get it installed.due to weather may be a while for road test
