New 21" wheel, brake question
I recently installed a 21" wheel with matching rotors from PM. Now I feel the front brake lever pulsating like there is a high/low spot on the rotor or maybe something with the old pads. Has anyone experienced this after changing out the front wheel? Should I change out the old pads for new ones? Suggestions??
Also, how far is the axle supposed to go into the fork? I noticed there is a high spot on the axle where the hole is (opposite of the axle nut.) Is the axle supposed to go in all the way to that point because mine doesn't. Maybe this has to do with my brake problem???
Help????
Help????
Some will tell you not to install new pads some will tell u yes. At my shop I have always reccomended putting on new ones anytime u install new rotors. This will allow the pads to wear to the new rotors. I have pads wear more in the front or more in the back of the pad. Can't really explain it but it does. Install new ones is my suggestion.
The axle should be flush. Good choice of wheels. It was so hard for me to decide on my pm wheels as they have a great selection. Your gonna love it.
Also, before I installed the wheel, I talked with PM and they told me the rotors were all tightened down so no need for me to do it.
wheel shim
I had the same problem with Hogpro 21 front wheel. I had to shim the wheel to the right .050 to get the rotors centered in the calipers. Then I replaced the rotors with Lyndall floaters. I think I had a 2 part problem, the hogpro rotors were 1 piece and they warped, next was the wheel off center.
