PcIII?
PcIII?
With all this talk of tuners lately I have a question. When running a pc with o2 eliminators. When you have it custom tuned at 4500 elevation what happens when you ride down to lower or higher ground? Does the map compusate? Just so you know I'm running the pc so I'm not trying to bash it
The map doesn't need to compensate. The bikes fuel system does that with it's map sensor. That feature is not nuetralized with the addition of the PCiii. None of the systems (stock or otherwise) compensate for humidity. Temperature correction is accomplished with the air temperature sensor. All factory correction features still funtion with PCiii.
