Fuel Moto AFR's
We generally set the AFR between 13.0-13.2:1 at wide open throttle for the dyno runs we post. This depends on the application and what the motor wants.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Stock bikes run 14.6:1 in closed-loop mode, and the FM maps I've seen use target-AFR's around 13.7:1 in the cruise range, tapered down to 13:1 at 80% TP and above. This is a good AFR in the cruise-range for cooling and throttle-response but mileage will suffer somewhat. The fix is a map switch, but that's another subject.
