Increasing passing lamp wattage?
Old 02-22-2010 | 12:03 AM
ezryder62881's Avatar
ezryder62881
Default Increasing passing lamp wattage?
Ok here's a silly question for all ya'll electrical types.
I'm thinking about replacing my stock H3 halogen bulbs in my passing lamps on my '08 Ultra with yellow H3 bulbs.
I understand the stock H3 bulbs are around 35W. The Nokya replacement H3 bulbs are 70W. Seems a VERY big difference to me, and I'm wondering if the circuit will stand this without blowing fuses?
I also found yellow H3 bulbs that are 55W. Will the 55W bulbs be too much?
If so, can I increase fuse wattage without worrying about melting wiring?
Any feedback will be much appreciated. Thanks in advance!
Old 02-22-2010 | 12:16 AM
hatchetman's Avatar
hatchetman
You could most likely get away with 55 watts, I would not go to 70 though. Your biggest issue will be your stator output and your battery drain because you would be taxing your system!
Old 02-22-2010 | 09:15 AM
Badfinger's Avatar
Badfinger
Do you just want to be more visible in daylight or want to burn out oncoming drivers retinas? Check your bulb type I don't think your 08 uses H3's I'm pretty sure its an 881 type base, the angled one. Your can get these bulbs in 27.5 watt.
Old 02-22-2010 | 09:26 AM
HalfFast's Avatar
HalfFast
A 35 watt bulb pulls 2.9 amps. A 55 watt bulb pulls 4.6 amps and a 70 watt bulb pulls 5.8 amps. You would multiply these numbers by 2 to get the amps pulled by your passing lamps. Your wiring is good for about 30 amps but your fuse is 15 amps for your passing lamps. The trick to running high wattage bulbs in your passing lamps is the higher wattage you run, the higher temp the bulb will be. Your passing lamp are small and have no way of venting this heat so you will most likely blow a lot of bulbs or melt your plastic lamp connector on the back of the bulb.
Old 02-22-2010 | 09:34 AM
HalfFast's Avatar
HalfFast
If you are wanting more light from passing lamps, I would suggest going to a true HID H3 bulb and HID ballasts which will pull considerably less amperage and put out a much brighter light. These HID systems have digital ballasts which are very small and easily hidden in the back of your headlight bucket or elsewhere on your bike. These systems are also quite cheap if you buy them from such online businesses as DDM Tuning http://www.ddmtuning.com/index.php?p...=107&parent=61
Old 02-22-2010 | 09:44 AM
xxxflhrci's Avatar
xxxflhrci
I ran 100 watt sealed beam aircraft landing lights in mine for a while. The wiring handled it fine. I quit running them, because I blinded everybody on the road.
Old 02-22-2010 | 10:14 PM
ezryder62881
Thanks for all the feedback guys. I don't wanna blind anyone-just be more visible. I think the 27.5 watt bulbs posted by Badfinger are the best bet. Guess I'll pull one open and see for sure what bulb is in it. Thanks everyone
ckamin
09-08-2012 02:40 PM
Garemlin
08-27-2008 01:25 AM
autobahn
05-08-2008 05:54 PM
Garemlin
02-09-2008 09:51 PM
hywy2hl
10-20-2007 08:33 PM
