Grease dripping from neck bearings
When it's hot out, over time the grease drips out of the neck bearing and makes a mess. I've tried several different greases and they all do it. I am an Amsoil dealer and I am currently using the waterproof lithium base high temp (blue) bearing grease. Leaks out like crazy when hot outside.
Anyone else have this problem, and if so how do you control it. I can assure you I wont grease the bearing again, was just fine from Harley the way it was, only have 20K on my Ultra SE3.
I'm going to make an oil adsorbing pad and place it in the area to help adsorb the grease, unless anyone has any ideas.
Steve
Steve
Ron Jewell
09-05-2018 10:55 PM
