Help!!! @#!@$# fob
Help!!! @#!@$# fob
I recently took my fairing inner and out off had it painted. Sent my gages to have the LED's color changed. I put everything back together, however, now my damn FOB is not synking with the scoot.
Can someone tell me what I need to do to get it to work so I can start my bike.
There has to be something to do a code etc.
Thanks..
Thanks..
my fob stopped working a few weeks ago. went to SD Harley and was thinking it wasn't sinked.... end result was the battery went out on it. only had it eight months. bought a Harley battery 6 bucks. later found out the battery at walmart for 1.29 was the same battery. i don't know how old your battery was, may want to change out the battery before you take the bike apart again...
To change out the battery, look at the said of the fob you will see a little notch, I used a quarter and twisted it sideways and separated the flop. The batter is right there. Just make not on which way the battery goes in. If you put the battery in backwards, HD will have to reprogram the fob for 65.00, that’s what they told me at least…. Hope this helps
