Motor mounts
Old 02-19-2010, 10:01 PM
vickon's Avatar
vickon
vickon is offline
Default Motor mounts
My '08 FLHTC is about to hit 25K miles and I want to check the motor mounts, so;
1. What's the correct procedure to check the motor mounts?
2. What should I be looking for?
Thanks!
Old 02-19-2010, 10:23 PM
AlaskaAviator's Avatar
AlaskaAviator
AlaskaAviator is offline
If your motor is missing then I would suspect defective motor mounts.
Old 02-19-2010, 10:28 PM
vickon's Avatar
vickon
vickon is offline
Motor is not "missing", buzz on footboards and front vibration specially when downshifting and braking. Just want to check them out.
Thanks
Old 02-19-2010, 10:34 PM
AlaskaAviator
I would look closely at the front mount near the oil filter. If it is bad it would look smashed allowing metal to metal contact.
Old 02-19-2010, 10:45 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
I was told with my 07 Road King that if a motor mount broke it would feel like the motor was trying to jump out of the frame.
Old 02-19-2010, 11:23 PM
mongomark's Avatar
mongomark
mongomark is offline
It doesn't have to be quite that collapsed in order to pass on a lot of vibration. A couple of the aftermarket mounts are far superior to the factory replacement. Both Glide Pro and Velva Ride are excellent choices. Rather than rubber, they both use urethane which doesn't break down like the rubber mounts. Really high quality pieces. Do a google search and check out their websites. I've got the Velva Ride on mine.
Old 02-20-2010, 06:47 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
If you still have warranty on it take it to shop have em look or replaced em if not look for dried up cracked rubber or oil soaked soft mushiness new ones are tough built but that leads to more vibrations compare to 04 or earlier ones .
Old 02-20-2010, 06:55 PM
AlaskaAviator
Doesn't the urethane ones transfer a little more vibration compared to rubber?
Old 02-20-2010, 06:57 PM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
I put a Velva Ride on mine and it shakes less at idle, but I do feel a slight buzz in the floorboards from time to time. Not steady while going down the interstate, but just every once in a while.
JustDave71
Touring Parts
04-22-2013 07:04 PM
orangedog350
03-03-2012 09:22 PM
PHA-Q
12-01-2011 05:29 PM
hd99flhpi
Exhaust System Topics
05-08-2009 04:42 PM
sgt joseph
10-14-2007 01:40 AM
Quick Reply: Motor mounts
