Bad Battery or Charging System??
+1. Get a Battery Tender, your battery will love for it!!
Most likely a bad battery. If you have a problem with the charging system, the engine will stop running. Pull the battery, take it to Advance Auto, and have them test it. Or, seeing as how your bike is still under warrantee, take it to the dealer and have them check it out.
And, just to clarify, that is NOT normal. Even with the security it should last several weeks or more.
If the battery is bad I hope the dealer will help you out but there's a battery exclusion in the warranty I believe.
Specifically "This warranty does not cover: Parts and labor for normal maintenance as recommended in the Owner's Manual, or the replacement of parts due to normal wear and tear including such items as the following: tires, lubrication, oil and filter change, fuel system cleaning, battery maintenance, engine tune-up, spark plugs, brake, clutch, chain/belt adjustment and chain replacement."
Seems like that gives a dealer a fair degree of wiggle room.
If I recall the warranty on a new bike battery is really short (compared with auto batteries). Short like 6 months short (maybe a year) . . .
