Silly Question on '10 RG Odo / A-B Trip Mileage Reset Button
I just looked over every page of my owner's manual and cannot find anything on the reset A/B Trip and odometer button. I know I can cycle through the odometer, Trip A, and Trip B and hold the button to reset the mileage on either A or B.
But when cycling through the displays with the reset button, there's also a display with a lower case r with an apparent mileage reading to its right. If I press and hold the reset button on this display, it will flash once. It doesn't appear to reset or change.
Can anyone explain?
Thanks in advance!
Can anyone explain?
Thanks in advance!
Can anyone explain?
Thanks in advance!
Can anyone explain?
Thanks in advance!
It is approximate, but pretty damned accurate. When you've got less than 10 miles remaining it just says "LOW"
When the idiot light on the dash comes on, your odometer also switches automatically to the range display regardless of where you had it - just in case the amber light wasn't enough to tell you to get gas. I think the amber light on the speedometer starts blinking when you hit <10 miles remaining on the reserve as well.
So - in short - if you end up having to push it, its your own fault
Can anyone explain?
Thanks in advance!
Can anyone explain?
Thanks in advance!
jimmy z
04-06-2019 02:42 PM
