thinking of regearing
Hey Guys,
Ive read all the threads about regearing. I have an 07 RK custom that is now 103 with true duals. My buddy had his 06 street glide worked an is now 95 but he is just as fast. I hate the gearing in mine and have read all the threads. Im leaning torwards 31t primary sprocket from Evolution but not sure about the negative effects i might encounter. I realize I will lose my 6 gear light but concerned how it will run at highway speeds. Ive read about changing the rear pulley as an option but something about IDS and im not sure what that is. Can someone explain a little more on this subject. Im really confused now. Thanks.
My 07 Heritage 103 Rinehart 2:1, 257cams, heads, valves etc. has been regeared. I am no engineer but it definitely helps me get to the sweet spot of my cam faster. I still can't beat my buddies 95s with a 50mph roll on (me in fifth them in fourth), those 95s are torque monsters, but I can school them on an all out drag where I can get up into my power range 5,000 rpm +. There is a definite advantage against other 103's. Just wondering are you running stock throttle bodies and injectors?
Hey Guys,
The compensator is part of the stock motor primary sprocket. It absorbs the some of torque pulses of the motor and smooths out the power running back through the clutch, transmission and final drive. The compensator sprocket is 34 tooth. When you go to the 30 tooth sprocket there is no space for the compensator and it is eliminated.
If you go with the Andrews 30 tooth drive pulley, you will end up with a ratio of around 2.94, vs the 2.79 stock. Lots guys have gone this way. Doesn't mess up your 6th speed indicator. But your speedometer will be off, which you can get an adjustable device for that if you don't want to go the TTS way.
I tried that non compensated 30t primary sprocket last spring and it sounded terrible in the bike, when the chain snaps there is no more compensator to absorb the shock, it's just bangs against the crank shaft, I removed it after about 75 miles.
This year I installed EVO's 49T ring gear and it is very quiet because you retain the stock compensator and the performance is very simialer to the 30T.
FYI with the 30 tooth drive sprocket, you will probably need to replace the drive belt with a shorter one as well.
HDF Tech
06-19-2011 05:50 PM
