Yes the mount changed in 2010 and uses a shoulder bolt on the bottom instead of a locating pin. If a dealer does warranty work, they have to replace the faulty part with the most updated part so you should get the updated part if they are doing their job properly.
dan1127, was your mounting bolt chrome or non chrome plated? I was just wondering if the chrome plating makes the bolts more brittle? I too don't want one snapping when the wife mt/dismounts.
52719-93B is the old bracket and still shows as active, but if you look at 52719-10 it shows as superseded from 52719-93B. I would insist on the 52719-10 if having warranty work done.
Dawg, Have You got any part #? ...............PS: Where is Soos?
