Cam Swap + Lifters ?
I did some searching and could only find the Crane 10530 in pairs and packs of 16. The pair cost around $35-40 while the 16-pack is about $215. If you bought the large pack and could get rid of the extra 12 lifters you could get four for about $54.
I changed the lifters in my '96 RK Evo at 65k as a precaution only, thinking they might be the problematic small-axle type, and the second set is still in there at 120k. The originals were the early big-axle type while the replacements were "B" big-axle lifters for Evos (different from TC).
Troop: I replaced my lifters with new stock (B) lifters when I did my cam change at 32,000 miles. Opinions differ. Some will say that the new style lifters don't create wear patterns on the cams. I decided that since I was in there already and had some pretty good mileage on the bike, I'd be safe and change them. If I only had a few thousand miles on the bike, I think I would not have changed them.
Mark: Depends on the year of your bike. '07 and later have they hydraulic tensioners which work great and don't need the attention (replacement) of the earlier tensioners. If you have a pre-07, I'd change to either the hydraulic or chain tensioners. There is a LOT of debate on the forum as to which is better. I'm very happy with the hydraulic system and use bolt in cams. I think that when you buy the get the hydraulic tensioner system as a retrofit, you also get the heavy duty oil pump. If you go chain, you need to check your run out to make sure you are within tolerance or you are likely to have problems. You may want to do a search and read some of the threads to help you decide which way to go.
I changed the cams on my '07 at 25k and the tensioners looked nearly new, not more than 10% wear on one, only minor scratches on the other--so I reused both.
My '01 Ultra went in this winter to the stealership for the SE Hydraulic upgrade kit install. As the 3rd owner & at 44,140 miles, I wanted a look-see. I two-up a lot and since I will be in there already - change the cams to SE-204's for some more torque. It is only a stock TC88. I get a call, "your cams are scored!" The front cylinder lifters scored the lobes greater than .050". The replacement lifters are $95.84 (that's with a 15% discount). The rear ones were okay. When all was said & done it cost me $1500 for the complete upgrade. We're talking every component in the cam chest is new.
kdfcogwheel
__________
TC88, SE a/c, Kerker slip-ons, SE-204's, Pwr Comm III
HP=68.58 TQ=80.77
kdfcogwheel
__________
HP=68.58 TQ=80.77
Crane 10530's
Are the Crane 10530's the actual lifters mfr'd for H-D ? And where are you finding them in pairs? I only found 16's and 12's. Thanks, Troop
** I did find them (4) for $75/shipped from PAW in California. If they are the ones, quite a bit cheaper than the 18538-99B's .
Hey iclick,
I can't find 10530-4 anywhere, but PAW has the 2-packs. At $66 that's a decent discount over HD's inflated price. Not sure what PAW charges for shipping, though.
