Woods Cam install...The start of my questions...
I didn't line up anything on mine until I put it back together. why line up the timing marks just to take it apart? Sounds silly to me. Just cuttem and get on with it. It's not brain surgery, you really can't mess anything up. I've done a couple of them like that and no problems at all, don't sweat it , it's an easy job.
BTW, while the cam-lock tool makes the job a bit easier it really isn't necessary, as you can just have a helper hold the brake when the bike is in gear while you remove and later retighten the sprocket bolts. OTOH if you did a lot of cam jobs it would be worth it to buy the tool for the convenience factor, IMO.
Secondly, I just realized I forgot to order the cam lock tool. Can I finish the job without it, or is it a necessity???
Make sure both lifters are down as much as they go and then cut away! Take some time to spin the rear wheel to watch the lifters go up and down. When the OPPOSITE cylinder exhaust lifter starts to go down and the intake lifter starts to go up, then you are on the compresson stroke of the cylinder you are working on.
Use a straw in the spark plug hole while rotating the rear wheel and find the top piston position. Mark the straw for later use. Both lifters on the cylinder you are working on should now be down.
This is the position you cut the pushrods and then later install them.
Your dots will not be completely aligned at TDC Compression.
Align the dots before you remove the gears, cam plate, and cams. This way everything will go back together perfectly.
