led strips
Old 02-21-2010 | 05:05 PM
customsoftail200's Avatar
customsoftail200
Originally Posted by screws4156
They are HD saddle bag spoiler lights. They can be wired for brake and running or running and turn signal lights.
I have them on mine, I use them as turn signals. They're pretty cool.
  #42
Old 10-27-2010 | 08:14 AM
2010David's Avatar
2010David
1st Gear
I like the blue led strips on my cars,sooooo amazing and attractive ^_^
  #43
Old 10-27-2010 | 09:39 AM
jberg's Avatar
jberg
I used them to illuminate the interior of my tour-pak and put two smaller ones under the speaker pods to light the saddle bags. I tied them into a switch and a acc power source. I don't use them for exterior lights but the are quite bright.
  #44
Old 10-27-2010 | 12:29 PM
cayers's Avatar
cayers
Not real keen on the green either. I got six others to pick from.
Screw where did you get the engine guard driving lights? I've been looking for ones that mount there without any luck.
Thanks
  #45
Old 11-11-2010 | 04:10 AM
2010David's Avatar
2010David
1st Gear
Default Led Strip
Hi Bikerick,not all led strips are the same brightness, depending on what type of leds. I purchased my led strip headlights from the Hero Led, you may have a search. That uses low power side-emitting smt leds and waterproof with backed self tape.
  #46
Old 11-11-2010 | 04:53 AM
BigDaddyMike's Avatar
BigDaddyMike
I got a kit from "Joe Florida" No soldering, just cut and plug and play. Mounted a strip under the fuel tank, small strip behind horn and air cleaner and a longer strip, facing in and down on bottom of frame. Looks like you're riding on a cloud at night. Also I got the multi colored ones because different jurisdictions are somewhat picky about what COLOR lights you can have...Here is a short video I did after the install in a dark garage.
  #47
Old 11-11-2010 | 06:19 AM
vnelson79's Avatar
vnelson79
I have the LED's if you guys need, I sell in several different packages. Just let me know what you guys need and I can customize a kit for your bike
RoadTrippin'
09-09-2020 09:56 PM
Rick carter
10-24-2019 07:44 PM
Karnevil
Europe
01-30-2013 01:10 PM
xantasm
09-15-2011 05:33 PM
cloverhsu7
Electrical/Lighting/Alarm
05-13-2011 09:28 AM
Quick Reply: led strips
