Ultra Bottoming Out w/Low Touring Air Shocks
Just added profile low-touring air shocks to lower new Ultra Limited but find that it is bottoming out on occasions. I think if I add air to 50# it will help, but dealer says it is a result of lower shock travel. The MOCO just came out with a hand-adjustable low touring nitrogen-charged shock. Item number 54680-10; pricey at $499.95. Does anyone have any experience with these shocks or similar ones from other vendors?
I now have the new **** shocks on my 2010 Road Glide. Came on my bike due to a dealer swap. The **** shocks do not bottom out but the ride seems to be a little stiff. I wouldn't pay $499 for them.
You need to play with the air pressure. I have the shorter shocks aswell and I weigh 160 and run 10 to 15lbs solo and only on the biggest nastiest bumps does it bottom and when my wife rides I bump up the pressure to 35 to 40psi and rarely bottom out. So I would play with the pressure a little and remember that you do have 1in less travel than the stock shocks and a sacrifice has to be made somwhere.
Hope this helps Tim
Hope this helps Tim
I've used the HD low profile shocks on 2 bikes now. My 06 Ultra has about 32,000 miles on a set now along with the lowered front end. I've taken many of trips with the bike fully loaded and the OL on back and have had no problems with bottoming out. I weigh about 230 and the OL is right around 130. When my dad used to have his 06 Ultra he had the exact same setup and took many of trips with my mom and had no issues. I run 45# pressure when I'm fully loaded up.
