White LED Gauges (MyRide7)
The LED's in my speakers are 15" flex light strips from wal-mart. You can also use the 18" flexible light strips from advanced auto or auto zone. I wrapped the light strip around the inside circumference of the spacer that goes between the speaker and the grille. If you use the 18" flexible light strips you will have to cut off the last 3 LED's.
Anyone know the current supplier and which larger LED is needed for the odometer in the 06's? I have ordered the smaller back lights from unique lighting already, just need the ones for the odometer. The link I have tried for the guy in PR is not valid.
Found it in case anyone else needs it
http://cgi.ebay.com/ebaymotors/HARLE...Q5fAccessories
I am definenitely sending my gauges to Marty ASAP!!!!! Scott and/or Marty. Did you just order the white Led's or I seen that they also have a super white. Not sure what would be the difference. I just want to make sure that they match the led's I will be using with teh smaller guages. Thanks!
link no worky
[quote=Taylorized;6278954]Sent gauges to Myride7 and radio to Ironcross. Speakers are Autozone led strips. Thanks to Marty and Tricken Addixion. Little gauges are Wdege 5 from http://www.superbrightleds.com/specs/bulb_specs.htm Enjoy
LINK NO WORKY!!!! want to know exactly what bulbs to order form brigt leds. com...maybe a part number?
