Shutting down in gear -vs- neutral
RE: Shutting down in gear -vs- neutral
MSF had those Uncle Ben bikes with all kinds of safety switches.
Personally I always shut down and start in Neutral and do not use the kill switch.
The exception is when I feel that I need the additional staying power that first gear provides like on a hill. Then I use the Kill switch as a reminder and start in gear with the clutch in.
What I feel is more important is waiting for the fuel pump to come up to pressure.
But this is certainly without technical merit. Just my way!
I SHUT DOWN IN GEAR AND THEN GO TO NEUTRAL. NEUTRAL IS MUCH EASIER TO ENGAGE WHEN THE MOTOR IS NOT RUNNING BECAUSE THE TRANNY SYNCHROS ARE TURNING WHEN THE ENGINE IS RUNNING. THATS WHY YOU SEE GUYS REPEATEDLY TAPPING THE FRONT SHIFTER FISHING FOR NEUTRAL WHEN ALL IT TAKES IS ONE CLICK ON THE HEEL WHEN YOU ARE IN FIRST WITH THE MOTOR OFF.
Interesting question. I've always shutdown / started my bikes in neutral unless I'm forced to park on an incline. I've never had a neutral light lie to me but I suppose that's possible. I never use the kill switch either but that's probably just personal preference.
ORIGINAL: imcav8r
So does that mean that with the clutch in there is more starter drag than simply having the bike in neutral? MSF teaches to hold the clutch in while starting even though the bike is in neutral. These are all good answers but I think they're still missing something. I like to know how and why something works, not just that it does work. It always helped me in the long run when trouble-shooting problems and even help prevent future problems.
When your bike sits over night, some of the oil squeezes out from between the clutch plates. This causes more friction between the discs. When you pull in on the clutch lever, there is still some friction between the discs and this causes drag on the starter. Try this - hop on your bike and pull in the lever with it in gear, hit the starter and see if you feel the bike trying to move ofrward.
By putting the bike in neutral, the additional load of trying to move the bike forward because the clutch has not completely released is over come.
Need more of an explanation or clarification on any of this, just ask and I will try to help.
The '07s won't start in gear without the clutch pulled in. I was at the Stealer when they read it in the owner's manual and tried it out. In gear no clutch the starter won't turn over. It's about time. I was holding up a bike once for a guy to see how it fit. I was holding the front wheel between my legs when he decided he wanted to hear it run. He thought it was in neutral, (or he was an idiot) and hit the starter. Tried to turn me into a soprano.
I always park my bike in first unless I'm in my garage. Starts the same in 1st or neutral, doesn;t matter. There is a slight drag on the clutch if its cold when I start it. I have never heard nor intuitively do I feel that shutting down in gear could harm the transmission in any way. I get aroung the issue of mistakenly starting it without the clutch pulled in because I have a police model. They have an interlock on the clutch.
I've always shutdown/started up in 1st.
That theory about the scoot wanting to roll/lurch forward when cold even with the clutch pulled in is a FACT - I've always wondered WTF was going on???
From now on - shutdown in first - startup in neutral for me. THANKS for the tips. HD forum strikes again.
