Rodger McEwan Oil Temp Gauge
I couldnt find the HD one, and I got this one for 75.
Seems pretty easy for me to read.
I dont know enough about the oil galley to speak of that.
I will say, I expected it to match the HD Gauges better. But so far.. I am not upset.
Will give it sometime before I decide.
The more i think about, the more I would rather have a cylinder head temp gauge.
I may have to find one of those instead. I just want something that matches the other gauges.
Main oil feed
I wasn't comfortable with the sender and its large diameter end sticking into my main oil feed as it does. Maybe its not that big of deal but at least i observed it and am not having that on my bike. The adapter keeps the 1/8 sender from restricting that oil galley at all and probably for a reason. I'm sure some just crank the McEwan sender in there not paying any attention. It sucks the whole setup is shtty, gauge always looks pegged and hard to read the numbers all tight together above 170 and really does not match that good . The lights not as bright and it leaves a little notch at the top of the fairing that light shines through unless you put a piece of tap over it on the inside of the fairing on some years. I sent mine right back and got the hd one much better period.
The drag is that we are conditioned to look at a guage and if it's in the middle then it's normal. But the McEwan gauge only goes to 300 degrees and normal riding temperature would be on the high side of the gauge.
I ended up buying the HD gauge. It was out of stock everywhere. I ended up having my local dealer print me a list of all U.S. dealers that show it in stock. Finally found it in Colorado. Even got a 25% discount. Nice gauge. Be sure to look for RevA.
oh yea... the HD goes to zero.
they must have changed the RM gauges. mine does not looked pegged out and goes to 0 when the bike is off. mine goes to 300* and normally runs around 200-220* easy to see and has been great for the last 5 or 6 years. The oil galley is not plugged and if you actually see the oil tank off you can see the probe does not inhibit any oil flow. This is on an 04 flhtc so maybe different on t/c96's. There is an adapter that the probe screws into and the probe would not work without the adapter. My RM reads exactly what the dipstick temp gauge reads on mine. My buddy got one of the digital dipstck ones and I tried it out to compare the two and they read the same.
I currently have this gauge installed on my 2005 Ultra Classic and I'm trying to replace it with the Dakota Digital Oil Temp gauge. I am having a problem removing the reducer bushing that goes into the oil pan; it seems as if the Rodger McEwan sending unit is 2 parts (sending unit & thread reducer). I am willing to buy a copy of the instructions from you; I am at a "standstill" with the project until I can get this removed.
Thanks!
Thanks!
gauge
Installed mine last night.I bought it from the 2010 HD book and it matches really close,Starts at 110 and goes to 350,The sender went in the oil pan and the total time to install was less than two hours.Havent tried it yet too much snow.backlite seems to match,chrome bezel is a little different. paid 140.00 that extra money must be worth it considering the problems some of you are having.
