Use turn signal O ring seal or not
02-11-2010, 11:34 PM
Do you folks replace those little O ring seals on your turn signal lenses when the fall apart? Do they really do any good?
02-11-2010, 11:44 PM
Quote:
Originally Posted by
TheBagger
Plastic to plastic or plastic to metal w/o an O ring could cause an avenue for leaks. I would think.
02-11-2010, 11:54 PM
Always reassemble things with all the parts that were removed during disassembly.
02-12-2010, 08:47 AM
The only o-rings on my signal lenses are there because of the bezels that I bought to go on them and they are needed to hold the lens out so the bezel attaches properly. They came in the bezel kit but are available separately. I don't know if these are the ones that you are talking about or not, but I'd replace them.
02-12-2010, 12:04 PM
Thanks dawg, the O rings didn't seam to seal up anything that well. They must be there to let the trim rings slide in behind the lense.
fatbob
01-15-2021 11:46 AM
Tinmanpope
Softail Parts
01-23-2017 12:38 PM
kaosj
02-01-2009 05:42 PM
ponesma
08-26-2008 08:59 AM
Tattooedlife
04-04-2008 06:26 PM
davidson ,
electra ,
gasket ,
glide ,
harley ,
oring ,
orings ,
ring ,
rings ,
seal ,
signal ,
signsl ,
trim ,
turn
