I have a 2005 Ultra with stock wheels. I am trying to find out what is the widest rear tire that I can fit on the bike with no major modification. I am also looking for a low profile tire. Does anyone have any suggestions on tires and sizes?
Sorry, I don't have an answer to your question. But FYI, try Jake Wilson for the absolute best prices for OEM Dunlop tires. (I'm just a happy customer).
If I am right your bike has 3" rims and 16" diameter. The largest tyre you can fit is a 150, such as an Avon Venom 150/80x16. I am in the process of fitting one to my 1990 bike! If you go with that size check the brand you prefer as they vary a lot on actual width. An H rated Venom is 150mm wide, but their V rated is 157mm. Some brands are even wider!
To fit a wider tyre you really need a wheel with a wider rim, which you may be able to get off a different model, such as a Softtail. Hopefully someone will pass by who knows just what is interchangeable.
I put a Dunlop E-3 160 on my 2005 RK fits with no problem.
Ditto here with no problems. I just installed the E-3 160/80-16 on my 07 electra glide classic. Too cold right now to see how they are. Way Too much dang white stuff too!
