Rampage lift vs. Haul-Master
Old 02-08-2010, 01:06 AM
SharkBite's Avatar
SharkBite
SharkBite is offline
Default Rampage lift vs. Haul-Master
Just curious if anybody has any experience with the 'haul-master' lift that can be purchased through Harbor Freight?
In appearance in looks pretty much identical to the Rampage lift that sells for about $2,400 but sells for $599.
Old 02-08-2010, 08:01 AM
timvan's Avatar
timvan
timvan is offline
doa search on here for Harbor Freight lift lots of guys have them. I have no experience with them, I have other brand lifts
BTW, you can find 20% off HF coupons in a lot of mags also
Old 02-08-2010, 09:43 AM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
Default loader
before i would buy the h. f. one, i would compare the thickness of the metal, I surely would not want to see my ride bending in the middle due to junk or thin steel. bty, i also have a rampage for sale in near new condition.
Old 02-08-2010, 10:52 AM
piasspj's Avatar
piasspj
piasspj is offline
Are you looking at the same types of lifts?
The only rampage lift I know of fits in the back of a pickup truck and is for loading the bike up.
I haven't seen anything like that at HF.
I just searched Harbor Freight and looks like they do have one. I haven't seen anyone mention it here, it may be something new.
If you get one I'm sure many people would be interested to hear about it.
Old 02-08-2010, 10:59 AM
kevdon's Avatar
kevdon
kevdon is offline
Default lift
I looked up the haul-master lift and downloaded the manual. it looks identical to the rampage, so i called h-f and they told me it is imported to the u.s. but if you look at the manual pictures you would bet they were from rampage's manual.
Old 02-08-2010, 05:03 PM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
DONT buy one.I had one for about a week.What a P.O.S.Sent the pile of junk back.The top plate that the front wheel bracket is welded to hangs up on the rearwheel plate when you try to load the bike.It looks to me that the wheels on the top plate are too small causing the top plate to push down on the bottom plate when you try to load the bike,which causes it to hang up.Another thing I noticed was that you better make sure that the lift /truck is on level ground,if not the bike and the lift could tip right off of the truckI look at it like this you get what you pay for and this was no exception to the rule.I will say HF was real good about taking the lift back and refunding my money.
James Criss (05-23-2021)
Old 02-08-2010, 08:07 PM
SharkBite's Avatar
SharkBite
I agree, i looked at the downloadable manual and it appeared pretty much identical to the rampage....too bad FastBagger had a bad experience with it, I was hoping to hear good things.
I looked at a used toytrax/jettrax lift a few days ago that a local guy has for sale but it's 10 years old...not in bad shape but i'd have to replace some bolts etc...he's wanting $1000 for his on craigslist or $1200 on Ebay...guess i'd go with the craigslist option ha ha!!!! He did agree to help install it and allow me to try it out to make sure it works properly (it's not mounted currently)...not sure if I want to drill a few holes in the bed of my new truck only to find out it's not working right!!!
Thanks for the input
Old 02-08-2010, 08:20 PM
2deuce's Avatar
2deuce
2deuce is offline
How much are you asking?
Old 02-09-2010, 06:47 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
Default rampage
I have it listed for $1800.00 but I will take $1600.00 bottom line.
Old 02-09-2010, 06:50 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
Default rampage
I should have have stated that if you have a fairly new ford, the install is very easy with no holes to drill. I have it set up to use bed bolts already there.
Quick Reply: Rampage lift vs. Haul-Master
