Ultra Limited Bumper Removal
I want to remove the ugly bumpers from my bike. It looks like I can get the darn bolts okay, but noticed the brackets had little tabs on them that make it impossible to get a socket on them. Is there an easy way around this? Is it necessary to buy the bracket for the rear?
on my 2008, I used a long-handled straight screwdriver and flattened them to get at the bolt. I went thru the rim, and was able to get them. you can rebend them from the outside when done. A major improvement from stock...I haven't done the rear bumper though. Awesome bike you have.
You should not need the support bracket after removal of the rear bumper. That is only up to 08 models. IIRC, the 09's have a different rear setup and you can take off the bumper without buying the support bracket. I took both off my 08 and like the look. I also used a flat blade and bent the tabs back. Did it all without having to remove the tire.
Tim
edit----forgot about the 09 10 frame change---only need rear bracket of 08 and earlier
Don't get me wrong, I'm all in favor of work-arounds if it saves time. I would get all kinds of frustrated trying to get at the inside of the fender with the wheel still on the bike.
