Street Glide Handel Bars
Old 07-24-2006, 05:56 PM
bdjhog's Avatar
bdjhog
bdjhog is offline
Default Street Glide Handel Bars
Does anyone know the width, rise and pull back of the stock handel bars on an '06 Street Glide? Thanks.
Old 07-24-2006, 06:31 PM
blowe's Avatar
blowe
blowe is offline
Default RE: Street Glide Handel Bars
Tip to tip
30.25"
base width
15.75"
rise
7.25"
pullback
6.25"
Old 07-24-2006, 06:35 PM
HD Renegade's Avatar
HD Renegade
HD Renegade is offline
Good Post, dam it now I want new bars!!!!!!!! I want more pull back!!!
Bob
Old 07-24-2006, 06:53 PM
bdjhog's Avatar
bdjhog
bdjhog is offline
Thanks. I'm also considering a different handel bar with a litle more pullback. Stock bars seems to give me that shoulder blade burn I used to get with my Sportster before I put on a set of Road Kind Touring bars. Thanks again for the info.
Old 07-24-2006, 06:56 PM
HD Renegade
ORIGINAL: bdjhog
That is why I get a sore left sholder!!!! Plus I could lean back on the bike more with bars that would come back to me more too.
Anyone out there have some recomendations for bars that fit on a Street Glide??
Bob
Old 07-24-2006, 07:29 PM
lp's Avatar
lp
lp is online now
Received 2,837 Likes on 1,597 Posts
Wild one has one that is pretty cool.
www.wild1inc.com
lp
Old 07-24-2006, 07:54 PM
blowe's Avatar
blowe
blowe is offline
ORIGINAL: HD Renegade
ORIGINAL: bdjhog
Bob
55914-98
Harley pullback bar.Fits '97-later Electra GlideĀ® models. Requires separate purchase of clutch cable P/N 38649-98, throttle/idle cable and Brake line Kit P/N 45212-97B.
tip to tip
30.75"
base width
15.00"
rise
8.00"
pullback
7.50"
These are supposed to bring everything 2' closer to you.Of course as others said Wild1 has some really nice bars if you like the larger diameter bars and internal wiring.I personally like the stock bars and the only reason I swapped mine was to install a set I had powdercoated black.
Old 07-24-2006, 08:16 PM
HD Renegade
ORIGINAL: Oliver Clozoff
ORIGINAL: bdjhog
Bob
55914-98
tip to tip
30.75"
base width
15.00"
rise
8.00"
pullback
7.50"
Oliver
Thank you for the info and part numbers. I was not sure if I would have to deal with cables too!!!! That sort of adds a few more $$$ to the whole deal.
Bob
Old 07-24-2006, 08:22 PM
blowe's Avatar
blowe
blowe is offline
Bob honestly Im not so sure you can't do it with the cables you have on the bike now rather than swapping.
I'm sure somebody here has done a swap for a similar bar and can answer for sure if you would need new cables or not.
Also have you thought about trying to rotate the bars back to you just a bit rather than changing the bars all together?
Old 07-24-2006, 08:30 PM
HD Renegade
Yes I do remember someone on here did it just before the riding season started too. I had not really thought about rotating the bars, that might be a good place to start for a little bit of added comfort too.
Thanks
Bob
Quick Reply: Street Glide Handel Bars
