Whick Chock HF Lift
Whick Chock HF Lift
Which chock is the best for the 1000lb Harbor Freight MC lift? Seems there are several options and all of them are in use by different members here. If HF doesn't sell out of the lifts, I think I have talked myself into buying one. Just wondering which wheel chock to go with. So opinions please....
Get the lift... Get the Chock. No need to spend more than $350 for ANY setup. JMHO~!
(found it)
https://www.hdforums.com/forum/touri...eel-chock.html
I have the same set up on my HF lift .I liked it at first it holds the bike steady but it's a pain in the *** to get the bike off of the lift .It takes two people one to hold the lift from sliding and another to rock the bike out of the chock.
The other thing it’s a tight fit on the front tire and if you use a service jack on the lift the tire gets hung up in the chock it could pull the bike off the service jack. It can be done but again it takes another person to help lift and guide the tire out of the chock. So I am looking for different chock. maybe an adjustable one so that I can fit different size tires and loosen and tighten the chock as I see fit like when I want to use a service jack.
I understand what you are saying about getting the wheel out of the chock. I built a "Condor" type chock for the trailer. Works great, but it is hard to back it out of the chock. (it is impossible to get out if you forget and leave it in gear)
There is probably a good reason all the high dollar lifts have a vise like on the link below.
http://www.derekweaver.com/update/Wh...uct.aspx?id=41
Appreciate everyones input.......Thanks
