Road Glide fairing removal question
Since I'm gonna be snowed in for a few days I figure I would finally crack open my fairing. I have read the process but do have a question. When removing the turn signals do you remove both nuts and pull the assembly completely out??
Also where in the service manual is fairing removal located. I looked in the index for the obvious but it wasn't there. Must be listed somewhere else.
I just pulled mine off for the first time a couple of days ago. Yes, the turn signals will pull-out completely, but they take a little wiggling/tugging due to the wires and the small hook which holds the wire inside the fairing.
In my '09 manual, outer fairing removal was in section 2.40. I scanned the 3 pages covering this topic for you - attached. GOOD LUCK!
check these links they helped me and are great videos of the process
http://s135.photobucket.com/albums/q...ingRemoval.flv
http://s135.photobucket.com/albums/q...ingInstall.flv
Thanks guys and especially thanks for that video link synergyhomes. I have always been more of a visual type of person over reading instructions. That helped a ton. Love the common sense tips that some of us would never think of like the painters tape and wrapping the signals in a shop towel.
These links are dead...Can you repost? I'd LOVE to see them...Thanks!
SquireJim
http://www.youtube.com/watch?v=3SuzH2ToplM
He doesn't show it in the video but make sure to protect your fender with a towel. First couple times you do this, it helps to remove the headlights so you can see how the fairing hooks line up. (if you go this route, make sure the headlight plug wires aren't hanging below the inner fairing when you attach the outer - otherwise, you'll be pulling it back off and cussing a lot. Yep, been there done that! lol)
