Is there a safe engine cleaner?
#31
That is true. It has been band for use on aircraft. Simple Green has an aviation safe formula but it is hard to find. I understand you can buy it at FBOs. I do use the regular Simple Green occasionally on the undercarriage but I rinse very well after. I would not use it at all on painted surfaces. Antique toy restorers soak toys in it to gently strip paint.
#32
#34
WD40 has acetone in it
I've been using WD-40 for years and it has been completely safe on metal and plastic. Cleans off grease, road grime, etc, and it's cheap! Spray on/wipe off. You will be amazed. Pretty certain it will take scuff marks off chrome but I have not tried that myself. Just mop up good before you take off so your tires don't slip on it and down you go.
Happy Friday All!
Murph
Happy Friday All!
Murph
#35
1 Post
'Honda Brite' is S100 (Says so right on the bottle) It's half the cost of S100.
I've been using this stuff since 1990 when their bikini girls detailed my bike 'cause it was so dirty THEY couldn't stand to see it.
Works pretty durned good. (But it is expensive!)
http://www.sitewavesstores5.com/mm5/..._Code=cleaners
#36
Simple Green
It messed the aluminum up on my dads 07 Ultra. Streaked it and turned it white. He let it set on there about 3 mins washed it off and when it dried he was sick.
#38
cvaria
03-28-2017 09:11 PM
