Any body have the rear lowering blocks as opposed to the shorter shocks?
Old 02-05-2010 | 03:10 PM
CT 06 glide's Avatar
CT 06 glide
i bought the road 6 ones also from ebay $24, should be here today i hope, also looking into shifting my wiring harness opver to the side as well. doing this on sunday so i will keep informed about it and hopefully pictures as well.
Old 02-05-2010 | 03:13 PM
HogFather's Avatar
HogFather
Had them on my 06 EG, no issues. They were great until we went 2 up and hit a good bump, the rear tire would rub the inner fender and finally wore out my harness. About 125 to fix. No more blocks. Invest more now and save later, go with the shocks.
Steve On 3's Avatar
Steve On 3
I got the white brothers kit and put them on my old Ultra. It rode extremely well but I di have to alter the amount of air in the shocks. I don't remember which way, just remember I had to change it. New bike seems lower so I elected not to use the blocks.
Bub
Old 02-05-2010 | 03:19 PM
jdreed520's Avatar
jdreed520
I have had lowering blocks on my bike for over 2 years and have had no problems....I am 235+ and the wife is 180+-, and like somebody said it will firm up the ride some so you will have to get used to that......but other than that they work great.
Old 02-05-2010 | 03:29 PM
r8rs4lf's Avatar
r8rs4lf
I also have the roadwhatevercustoms lowering kit that I purchased off ebay. Have ZERO complaints! I initially had it in the 2" lowering hole, but bumped it to the 1". The 2" looked good, but I was bottoming out a little. I never did check my air pressure though when in the 2" hole. Now I have it in the 1" hole and run 50# of air, NO PROBLEMS!
I believe he is a member here too.
Old 02-05-2010 | 06:15 PM
p.t.r.'s Avatar
p.t.r.
Originally Posted by ncbeast
I have a RG with the 13" and am 6'5" with a 36" and 245# and the wife is 130#. I would like to lower it just for looks but that is a big chance to take about smoking the wiring harness if it bottoms out. To be able to tell a big difference I would want to go at least 2" lower than stock. You would think there would be some kind of bump stop some where to keep this from happening or even messing up the fender if really low.
Has anyone every relocated their wiring harness over to the side so this could never happen?
Beast, I relocated mine after shredding it. I put an extre couple of inches in the harness, since I had it all out anyway.... It's a bad design by Harley. My old 97' Road King had the harness on the side, why'd the factory change it? So people like me could keep there soldering skills fresh, I guess.....
Old 02-05-2010 | 07:25 PM
redneckharley's Avatar
redneckharley
Talking
I put the lowering blocks on my '09 ultra and road about 400 miles on them an had to take them off. It changed the angle on my shock and caused the bike to bottom out if I had a passenger. As long as it was just me I had no problem.
Old 02-07-2010 | 09:08 PM
thewholehog's Avatar
thewholehog
redneck, I'm pretty sure there are several kits out thee that DONT change the angle of the shocks - road6customs?? eglidegoodies?? tjs products??
Old 02-07-2010 | 10:01 PM
Buzzsaw's Avatar
Buzzsaw
I had issues of bottoming out and rubbing the fender with the lowering blocks that came on my 97RK when I bought it. I changed out to the Progressive 440's and that fixed it.
I am using the lowprofile shocks on my new ride.
Old 02-08-2010 | 09:43 AM
LOW N BLACK's Avatar
LOW N BLACK
6th Gear
Just some food for thought. I did some research on this before i bought my lowering kit in 2007 and thought this was the way to go at the time . Since then ive bottomed out about half a dozen times and it sucks!! Did some more research and found a company in mesa az, bitchin baggers that takes your shock apart and lowers it. It will not bottom out and it can be lowered up to 2 1/2". Scooter rides great! Try them out.
