Dynamat for Batwing
I have it in my fairing. It seems to make the sound a little clearer. There are many posts from a while back on this subject. Try doing a search for dynomat. There are also other manufactures that make a similar product that may be cheaper.
I went to a car audio store and the technician went into the trash and gave me some scraps that were enough to do the inside of my outer fairing. The price was right!
I don't know if it the same stuff that you are talking about but I installed the j&m 7.25's. They came with a pre cut insulation mat that I installed in the fairing and there was a noticeable difference with and without the mat. Probably the same stuff your talking about, it is about 1/2 to 3/4 " thick.
I installed the dynamat insulation in my fairing within weeks of purchasing my bike. I also am unable to discern a real difference in the sound but I have to believe that it made it a bit "tighter" and keeps the bass (what little there is) from vibrating the outer fairing shell. If there's one drawback to installing this stuff I would say it's the weight. I'm guessing it adds somewhere in the neighborhood of 5 to 7lbs inside the fairing. This stuff ain't light! Got mine off eBay for around $15 or $20 bucks if I remember correctly. Here's some on eBay I found just now that will give you an idea. This is plenty to completely cover the interior of your batwing.
http://cgi.ebay.com/EXTREME-DYNAMAT-...item19b9961481
Brad
Brad
I bought and installed the Dynaxorb squares made by Dynamat and it reduces the vibration in the outer fairing which seems to provide better sound, though it's not dramatically different. You can go to Dynamat's website for an explanation of the theory behind the Dynaxorb squares.
The J&M liner provided with the 7.25" speakers is an open cell product; don't know whether it works any better/worse than other alternatives.
Good luck with your research.
you can purchase the die-cut pre-gummed acoustic foam pads separately, that are used in the J&M 7.25" speaker kits, at http://www.jmcorp.com/ProductDetail....SAP-HDCL&PF=43 ,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
