Enclosed Trailer Tie down location for Tongue wt.
I have a 6 x 10 v nose enclosed trailer. The mfg. shows the curb wt. at 1110 lbs. I weighed the tongue with no load inside and show on my scale 210 lbs. I am concerned about having too much tongue weight. Anyone out here have experience with a v nose set up. This is a 10 ft. trailer and the v nose adds 2 ½ ft. plus. Thinking I may need to set the bike towards the rear end of the trailer so as not to exceed 15% tongue wt. by too much.
I found in order to get my angle where the tie downs would be pulling slightly forward and keep the tongue weight right, I had to install the Wheel chock almost in line with the tie down rings I couldn't move them because they are anchored in the frame angle. My trailer was setup with a lot of tongue weight without the bike in it. I have the bike almost centered over the axle. You'll like the 6X10 v-nose. I don't know it's back there the way it tracks. Good luck!
That's how I did it, I also have a 6X10 V-nose. It's made by Carryon Trailer's in Ga. A pingle wheel chock came with it, but wasn't installed!
With my non V nose trailer I wanted to put at least one set of mounting bolts of my wheel dock through a steel cross member. The end result was that the rear of the Tour Pac was about 12/16" from the end of the trailer and a tongue weight of over 18% of the total trailer + bike weight. To bring it to 11% I placed my various bits of baggage as far back as I could get them and put my luggage in the tourpak. This still was not enough so i ended up placing some old hobby mags in a rucksack and placing it right behind the bike. I asked the trailer dealer why they had moved the axel so far back and he said that it was liability issues. Too many people had put too much weight at the rear resulting in trailers coming loose or suffering from major instability. This way, for people who didn't know how to set up a trailer the tendency was for them to put too much weight on the tongue which is considered the lesser of two evils.
I almost messed up hauling my '09 Ultra 2 days ago. I had to travel 186 miles on the return trip with the UC on a trailer that had angle-iron rails and expanded metal all the way around. The tie-down straps had to go over the rails to the tie-down point on the lower outside of the trailer. That is not a good way to transport a heavy motorcycle because the straps had to go over the sharp edges of the angle-iron. By the time I got home, one of the straps was cut almost in half.
Don't ever use a trailer like this to transport you scoot.
Too much tongue weight is not as bad as not enough tongue weight. Too little will cause the trailer to get tail happy and start to girate back and forth.
Take a look at a boat trailer or a ski doo trailer and were the axle sets. And they don't have too much tongue weight.
The worst trailers to pull are the tilt bed trailers with the axle moved to the middle so they will tilt. The trade off is they just don't pull good going down the road. They will girate unless you have most of the load on the front half of the trailer.
I really doubt that you will have too much tongue weight with your Harley inside your trailer.
just my 02 cents.
just my 02 cents.
RonRock
02-05-2012 01:01 PM
