Amber passing lamps...
Get some Krylon stained glass paint in the color you like and it will cost $10. Call it a day. http://www.createforless.com/Krylon+...utm_medium=cse
I'm tempted to do the same. What's involved in mounting them? Do I have to take the outer fairing off to completely remove the 2 passing lamp assemblies or I just have to unscrew the outer rings from the housings to replace the sealed beams? I have an 09 Ultra.
Thanks.
Thanks.
Regards Dave
Thanks.
Thanks.
How is it going?
I've had amber passing lamps on my Nomad for 8 years and I could see as clearly as with the white ones but not better. My main objective was to be noticed and the amber lights do a better job at it than the white ones.
As for the deer, just be careful, them critters don't care what lights you have. <g>
Doing good Fenchie I was to the Burg a few weeks ago took my Father to the Cancer Center for some diagnosis as he has melanoma in the blood. Well they found several spots in the brain and we have started radiation treatment. Follow up at John Hopkins in Baltimore and more radiation and then maybe some Chemo. Was a full day at each place, would have liked to been able join you for lunch but was no way to fit it in.
Checking the vendor you posted to see their pricing for the amber lights.
I also was going to mount them on my 05 Nomad but started getting serious about buying a Ultra and I am glad I made the switch.
The next time I make the trip to M&M Leather I'll give you a shout.
I run a pair of Wagner 4415A sealed beams on my 09 and like them very much.
These are screw terminal bulbs , fluted lense , amber.
They have a much wider beam spread at 40 degrees a opposed to the stock 8 degrees.
They're also 35 watt , and no problem for the stock wiring.
It "seems" as though "less" people try to turn in front of me at the last minute than when I ran with the stock setup.
Our local HOG road captain says they are noticeable enough , that he likes me at the rear of a group ride , so he knows where the last bike is.
Aim is critical (and aiming them is a pain) but I feel that it was a worthwhile mod to do.
I can buy these local for about $8.50 per and their lifespan is fairly short compared to stock.
Mick
Mick
I have been giving tis some thought, with all of the blue hairs driving down here anything to be seen during the day will be great. SO here is my question. Does it matter if you have an amber lens and white bulb, or a clear lens and an amber bulb? Which would be they better set up? I think I saw some PIAA amber lights that would work.
I was also thinking of doing the mod where the passing lamps will stay on even if the brights are on.
Thanks,
Thanks,
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
I have a 2012 Road King and surfed the web for hours and called Harley and can't find amber colored lights. I read through this thread. I looked up the Wagner 4415A then pulled my stock light out to look at the wiring. I guess I have to cut the plug from the bike and manually connect the bulb because it just won't plug in, correct? I don't know if I want to screw up the wiring. I also looked at the lens covers and they are 5" and my bulb is 4 1/2". Has anyone ordered the cover/film to see if it works? JP Cycles does not carry a lamp that fits my bike. A simple request for better lighting and a custom look is not so simple.
