Cam Installation Kit
Old 02-02-2010, 04:49 PM
iclick's Avatar
iclick
iclick is offline
I wouldn't recommend the HD Cam Install kit (17045-99C), which is now almost $100 (believe it or not) and is gross overkill since it has gaskets and bearings for every engine from Evo on up. Thus, there's a lot of waste regardless of what you own. It has seven bearings in the package, only two of which you will use if you buy Timkin inner bearings (B148 for early TC's, B168 for later), and you will use none of them if you have a newer TC96/103/110.
Fuel Moto has a model-specific kit ($50) that includes everything including Timkin inner bearings and all needed gaskets and o-rings should you intend on re-using your stock pushrods. Thus, there isn't nearly as much waste as with the HD kit. If you will be using time-saver pushrods you could save even more by buying only what you need, which wouldn't be much. Adjustable pushrods should have pushrod-tube o-rings in the kit.
Old 02-02-2010, 04:56 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by dawg
Cam service gasket kit 17045-99C will have everything you need. I suggest buying the SE inner cam bearings though or B148's elsewhere (SE are the B148's). You cutting rods or reusing? If going through the rockers and reusing, buy an air cleaner gasket as that is not in the kit.
I didn't know HD was selling the Timkin inner bearings under the SE name. Do you know the cost of these and the part number for both the B148 and B168 types? I couldn't find them in the 2010 SE catalog.
Also, is there a Timkin outer bearing available for the early TC's? If so, is this the best route to go or is the HD version reliable enough? I know they had trouble with early-TC outer bearings, but I assume they have ironed out these problems.
Old 02-03-2010, 12:17 AM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,318 Likes on 1,445 Posts
I believe the SE/Timken inner cam bearings are about $14.95 a pair.
I don't recall the part number.
andyshd
04-08-2015 08:37 PM
DXHD $100
01-01-2014 07:31 PM
deuce_streetbob
Exhaust System Topics
10-15-2013 10:14 PM
Skip
10-05-2012 09:28 PM
HD Roamer
03-16-2011 09:56 AM
Quick Reply: Cam Installation Kit
