Alarm wont shut off !!! HELP!!!
Old 02-01-2010 | 10:53 PM
Big Chris's Avatar
Big Chris
Default Alarm wont shut off !!! HELP!!!
2007 It's the hands free fob ... I have been moving the bike around in the shop a few time and all the lights flash ( no siren on bike ) . then today walked out there with the fob in my pocket! turn ignition on the lights flash and won't start (turn over). Tried to disarm with pin but I don't know the Harley pin number or if the guy I bought it from changed to his own pin number. So right now i have a bike in the shop I can't ride ! SOMEONE HELP !!
Also !
Is there some kind of timer on the alarm I should wait to try again and again! lol
Wheres the location of the alarm antenna ?
Big Chris
Old 02-01-2010 | 10:58 PM
user 8373900's Avatar
user 8373900
Put a new battery in the fob. The security system resets if it sits unmolested for a couple minutes.
Mark
Chasingdrakes (08-04-2021)
Old 02-01-2010 | 11:08 PM
Big Chris's Avatar
Big Chris
I have two FOB"s I tried both. And have tested Both 3 volt battery's.. They are reading 2.8 volts I think that is within the limits..
Old 02-01-2010 | 11:17 PM
Psychosis's Avatar
Psychosis
Try turning the switch to IGNITION with the FOB present to disarm and then look in manual and set your own PIN for the future.
Old 02-01-2010 | 11:21 PM
Psychosis's Avatar
Psychosis
I see you tried turning to IGNITION so you may have pull the fuse or just wait for the cycle to end. The antenna is located under the seat at the front of the rear fender.
Old 02-01-2010 | 11:44 PM
Big Chris's Avatar
Big Chris
How long is a cycle ? I waited 5 mins and it still wont shut off . turn on ignition .... switch to run..... push the start button ... nothing!! light start flashing ....... then I cuss!
Old 02-02-2010 | 01:28 AM
Big Chris's Avatar
Big Chris
help me lol
Old 02-02-2010 | 07:49 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Turn the ignition on with the fob nearby, then shut it off. It should reset. I had the same thing happen to me with my V-Rod and after trying everything else, I turned the ignition on, shut it off and it finally stopped screaming in my ear. Good luck.
Old 02-02-2010 | 07:56 AM
artt's Avatar
artt
I would replace the battery for the fob anyway. Static voltage readings really don't tell you much about the health of the battery.
Old 02-02-2010 | 08:11 AM
fladawg01's Avatar
fladawg01
Depending on how many times you have tried, you may have hit the maximum and now the only way to get this right would be taking it to a dealer for a computer override.
I have an older system and the dealer told me that I had 10 attempts after an override and then the unit would have to be reset by computer. Don't know if your is similar. Mine was an 06.
Quick Reply: Alarm wont shut off !!! HELP!!!
